seeking little Ge transitor tester project
Started by LizardKing, December 27, 2014, 03:49:26 AM
LizardKing
Anyone have a little project to make a tester to test gain and leakage of Ge trannies?
I have a collection of trannies I'd like to test and mark for future projects and wouldn't mind
making a neat test fixture to do it with!
Soup39
I think I have a spare etched board.  let me check the stack, if I do it's yours.
LizardKing
Quote from: Soup39 on December 27, 2014, 06:59:15 PM
That is very nice, but I can etch my own boards if you can lead me to the docs.
Even the name of the project would help, I've googled up nothing!
Soup39
LizardKing
Quote from: Soup39 on December 28, 2014, 01:04:08 AM
funny, the extra I have is rullywow.
IC, never heard of it.
That link gives me a:
We're sorry. You can't access this item because it is in violation of our Terms of Service.
Are y'all referring to this: http://www.rullywow.com/jfet-matcher-project-vgsoff/ ?
I did find the build docs with the pcb so I can etch one, THANKS!
Does anyone use an old Heathkit transistor testor such as an IM30?
I think I have one somewhere....
That one serves a different purpose. Here's a vero layout for a tester, if you add another strip of vero at the top and jumper it to the "E" strip you can test any transistor pinout without having to contort the leads.
http://tagboardeffects.blogspot.ca/2012/08/germanium-transistor-tester.html
LizardKing
Quote from: davent on December 28, 2014, 11:56:56 PM
Ah yes, this is the one that had wondering if someone had ever made a little project that didn't require a dmm or any math (direct reading).
I am thinking the answer is not.
Anyone interested in such a thing?
A cheap lcd, and arduino, and a simple board with power could be whipped up without too much trouble...
There's a little cheap chinese bare bones meter available that does a pile of useful tests for us outside the DMM realm, someplace 'round here there is a link. Not sure is does leakage but that's easy enough to test for.
Quote from: davent on December 29, 2014, 01:30:51 AM
I got a cheap Chinese tester and it does everything (resistors, capacitors, inductors, transistors), including leakage. It even measures ESR for electrolytic caps.
Here's more info:
http://www.madbeanpedals.com/forum/index.php?topic=16393.0
Yup, that's the one i was thinking of, thanks!
I use mine all the time. Basically, I use it for everything that isn't testing voltage or current draw.
LizardKing
Doing the research on this project, thanks!
