MBP Bass Compressor Recommendation
Started by benny_profane, May 09, 2022, 02:16:29 PM
benny_profane
I'm looking to round out a bass pedalboard build. On my guitar board, I use an optical comp; I've had decent results using it with bass. Since there have been a bunch of new comp offerings recently, I'm wondering which would be best suited for bass. I typically play fingerstyle but do use a pick occasionally. I'm more interested in a subtle smoothing rather than dramatic pumping.
I use a Bear Hug most of the time, it's pretty subtle and works well on bass in my experience. But if I were you I might wait until Brian comes out with the new Oracle compressor. I used to use a boss comp on bass and really liked it.
benny_profane
Nice, thanks for the recommendation. I'm not familiar with the CS-3. Is it a Ross derivative? How is the knee characterized?
I'm using the kompromat on everything. I love it. IMO it's the best for every use. The blend makes it as subtle or intense as you want and unlike other ota comps, Brian used the barber tone press circuit so it doesn't pump on high compression rates. Killer comp.
Compressors ate what brought me into the diy world of pedal building. I've found bass compressors to be a "to taste" pedal. I've built literally dozens, here's where I got. Bass optical compressors aren't great for live performances, the sound loses that sparkle, probably from being in the moment and playing a little harder than normal. I've played just about all of the diy compressors and landed on an EHX soul preacher. The bear hug would work about the same.
benny_profane
Great suggestions. Thanks. Interested to check out the Kompromat. I was assuming that FET comps would be the majority suggestion, so it's interesting to see an OTA design working well.
I think the main issue I've run into with compressors and bass is that the amplitude of the low end ends up overtaking the detection and eats up the high end. I know a blend is typically used to address this, but I'm interested in other solutions as well. A HPF sidechain seems interesting. Has anyone successfully implemented one in a comp design?
benny_profane
Quote from: EBK on May 13, 2022, 05:55:41 PM
This compressor is quite excellent for bass (I used it when I gigged):
http://www.thatcorp.com/pedals/4316%20Battery-Powered%20One%20Knob%20Squeezer.pdf
This looks interesting. Is there a board available for this project?
Quote from: benny_profane on May 13, 2022, 06:05:40 PM
Not that I'm aware of.  I built mine on vero.
benny_profane
Nice! What quad op-amps are you using there?
TL074 for both.  No need for anything fancier.
