Zero Point SDX, help needed: Why the delay distorts when strumming loud?
Started by Teddy, July 27, 2013, 08:55:34 AM
Teddy
I checked resistor values R8-R20, they are correct
what's next?
And thanks for replies, it's great to have support.
Thanks,
- Teddy
Teddy
they are correct
what's next?
Thanks for your replies, i really am thankful to get tech support.
- Teddy
kothoma
1) You are sure your guitar signal is not simply too hot?
2) Take a magnifying glass and closely inspect your soldering. There may be unwanted bridges or cold joints. Take a continuity meter and check suspect points.
3) Try to listen to the delayed signal at different points (between C16/R14, after C31/before the mode switch for a start) to find where the signal starts to degenerate.
Teddy
I will do the following, thank you.
I'll let you know, when i'm done :)
Thanks,
- Teddy
kothoma
Quote from: kothoma on July 27, 2013, 11:30:40 AM
Quote from: Teddy on July 27, 2013, 11:27:57 AM
Path switch on / off... works a bit akward. It makes the first repeat louder.
Yes, at least it could appear like that, because then the first repeat is unfiltered and has more highs.
Just to make sure, this louder first repeat is the most distorted one?
kothoma
One more idea. This distortion can be heard at all mix levels where you still hear delays?
(If not: check R40).
Teddy
Yes, the first repeat is the most distorted one.
Also, i think, the feedback pot is way too sensitive.
It oscillates before 12 o clock
-Teddy
kothoma
Quote from: Teddy on July 27, 2013, 12:28:49 PM
Glad to be of help. Good luck!
Teddy
Hello....
Just asking, how sensitive the feedback pot is supposed to be?
I think it's oscillating before 12'o clock
Thanks,
-Teddy
kothoma
Quote from: Teddy on July 27, 2013, 12:43:01 PM
Everything looks like your delayed signal level is way too high. Continue as proposed.
It's distorting either because of the diode clamp across the feedback pot or simply because PT2399s will distort with a signal larger than 2.5v. It's more likely to be from the feedback diodes since it doesn't distort as much when you flip the path switch (which redirects the first and thus loudest signal) and even the bare signal from a guitar is large enough to clip them(never mind one that's amplified by U1).
Teddy
Ok... i tried the ZP SDX with a drum machine, output level @ max
i hear no distortion ! crazy...
Then with a guitar, distorts badly.
I really don't know what to do..
I built myself a simple audio probe, to listen to the signal.
But i don't know really, what to do.
Thanks,
-Teddy
Teddy
Hello!
Thanks for giving me info on how to fix the SDX pedal.
I'm just thinking, that should i post a sound sample?
Off topic:
How to attach a sound file to the forum?
Thanks,
-Teddy
Teddy
Teddy
Here's a second sample,
a slower delay setting
-Teddy
