Zero Point SDX, help needed: Why the delay distorts when strumming loud?
Started by Teddy, July 27, 2013, 08:55:34 AM
Teddy
Hello!
I've built the Zero Point SDX.
Beautiful tone. everything works...
But, one issue:
The delay repeats distort, when strumming guitar loud.
Signal chain is guitar--->ZP SDX---->amp
Thanks,
- Teddy
Teddy
Hey, i forgot to mention that i used a 1uF film capacitor as C49, instead of MLCC.
Could this be the cause?
And also, i think the distortion is mostly heard on the first repeat of delay.
Thanks,
- Teddy
Teddy
hey one more thing...
i think it has something to do with the Path switch
switch turned off = delays nicely, without that much distortion
but anyway, it seems like the Zero Point SDX has little headroom.
Can this be improved?
Thanks,
-Teddy
Teddy
#3
and still a question:
Is it normal to hear "digital hiss" ?
When the delay is heard, there's a definite hissing noise underneath.
the strange part about the hiss is:
-when playing, while the delay is heard = hiss (like playing a chord and holding it)
-when not playing, while the delay is heard = no hiss (like strumming quickly and then muting strings)
-the hiss is worse with longer delay times
Thanks,
- Teddy
DutchMF
I don't think using film for C49 will cause your problem, as it is in the modulation section and you didn't mention anything else about that. The first thing that comes to mind is the PT2399's. Not all of them are created equal, try some other ones (preferably from another supplier) and see if that helps. Also, since you mentioned the Path switch, check all component values and orientation in the filtering section of the circuit (and the rest too...). Good luck!
Paul
Teddy
Thanks for your advice... i'll try change the PT2399's
Thanks,
-Teddy
Teddy
#6
Hello!
I tried changing the PT2399, still the same problem...
altough tone changed to a bit brighter.
I'll try to check the components in the filter section
Thanks,
-Teddy
Oh, could you be a bit more specific, where to look for a problem next?
kothoma
Quote from: Teddy on July 27, 2013, 08:55:34 AM
Distortion in every filtering mode?
At all or only high feedback levels?
Quote from: Teddy on July 27, 2013, 09:06:06 AM
Quote from: Teddy on July 27, 2013, 09:12:24 AM
Path switch turned off - thats no filtering on the first repeat, right?
Teddy
Yes, distortion in every filtering mode.
Path switch on / off... works a bit akward. It makes the first repeat louder.
kothoma
Quote from: Teddy on July 27, 2013, 11:27:57 AM
Yes, at least it could appear like that, because then the first repeat is unfiltered and has more highs.
kothoma
What about feedback level and guitar level?
Distortion disappears with lower levels?
Teddy
Guitar volume turned down = less/zero distortion
Feedback level doesn't change amount of distortion
kothoma
This is strange.
Just looking at Deep Mode there's not much (R39/C46) that could contribute distortion.
That would rule out the whole filtering section as culprit.
So maybe the signal is already distorted before the mode switch and filtering reduces this distortion somewhat so it is no longer noticeable?
How would you describe the sound of this distortion. Is it in the upper frequency range?
Anyway, I would start checking values of R8,...,R19.
Then looking for solderbridges, bad soldering, etc., the whole program.
Teddy
Hello!
Thanks for your quick replies!
I have an other issue.... that might have something to do with the distortion.
When delay is increased, hissing noise from delay repeats is loud.
And the delay sound quality is lower, the longer the delay is.
I will check R8-R20
kothoma
Quote from: Teddy on July 27, 2013, 12:03:23 PM
To a certain degree this is expected...
