Zero Point SDX, help needed: Why the delay distorts when strumming loud?
Started by Teddy, July 27, 2013, 08:55:34 AM
Teddy
anyone? bumping...
-Teddy
kothoma
Quote from: midwayfair on July 27, 2013, 02:00:48 PM
It's distorting either because of the diode clamp across the feedback pot
But the diode clamp is after the pot and he said it distorts at any feedback level.
I understand that already the first (not feedbacked) repeat is distorted.
So I would exclude this.
or simply because PT2399s will distort with a signal larger than 2.5v.
Either this or one of the feedback loops around the internal op amps is wrong, causing too much gain.
So either the input level of the delay line is too large or the output level gets too large somehow.
That's my best guess.
kothoma
Quote from: Teddy on July 27, 2013, 02:16:32 PM
Ok... i tried the ZP SDX with a drum machine, output level @ max
i hear no distortion ! crazy...
Then with a guitar, distorts badly.
Are the two input levels comparable? Can you measure them?
I built myself a simple audio probe, to listen to the signal.
OK, what do you hear after the first PT2399?
Teddy
hey, did you check the .zip files containing mp3's?
they were posted an hour ago
please, comment on them
is there anything wrong, or am i just dreaming...
Thanks
-Teddy
kothoma
#34
Quote from: Teddy on July 27, 2013, 04:58:20 PM
As I don't have one to compare (yet), I don't really qualify to comment on them.
Through notebook speakers it doesn't sound too bad to me ;)
Need to listen again through my nearfield monitors.
What settings did you use?
Teddy
Hey, im not sure of the settings, as i haven't put knobs on it =) =) =)
I think there's too much noise when using the long delay time
Oh, and to your suggestion on debugging the circuit:
When you say, probe after the first PT2399:
do you mean to sound probe after R14?
Where it connects to R21,R15, and R16?
kothoma
Teddy
Okay, i probed after c16
probe result: i hear a delay, that has a slightly noisy artifact.
-Teddy
kothoma
Teddy
noisy, not distorted...
ps. i did reflow some solder joints that seemed bad, and i think the distortion vanished.
but now i'm struggling with the noise/hiss issue
kothoma
Quote from: Teddy on July 27, 2013, 05:35:00 PM
Bingo! Congratulation!
Teddy
I presume this is the same point as point A on the rotary selector.
I hear a delay, its ok sounding. A bit of hiss.
But the problem with hiss is, that when i play while the delay is sounding,
the noise somehow amplifies. it's hard to say how it is, but that's
why i posted those sound files. =)
Thanks,
-Teddy
kothoma
Perhaps you should try a few different PT2399 more?
They seem to vary much in quality.
Teddy
will do!
i'll report after changing PT2399's.
- Teddy
Teddy
Okay, i changed the PT2399. Last fresh pair i have.... =)
Tone changed a bit, but the hiss problem is still there.
I'll post a new sound sample soon.
Thanks,
- Teddy
