Help! Cave Dweller + Taptation only has one repeat!
Started by brand0nized, August 05, 2014, 11:51:15 AM
Ahh, vero is hit or miss. All your components are correct and correct placement? The resistors are easy to mess up, an r where a k should be and vice versa.
brand0nized
I will double check, but as of right now, I'm 90% sure! but that's relative to my inexperience ;p
brand0nized
Now I'm pretty darn sure of my components.
My Cave Dweller worked before I added the taptation, so I'm guessing it must be the taptation board.
The Cave Dweller layout has a 5.1k resistor coming from pin 6 of the PT2399, should I be connecting that resistor to where the taptation is supposed to go to pin 6?
Quote from: brand0nized on August 08, 2014, 04:01:29 PM
i would put it in between pin 6 and the resistor, or directly to pin 6.
brand0nized
Just to clarify, I meant that I took out the resistor when implementing the taptation so I could connect the board straight to pin 6, so now I'm wondering if that resistor needs to be put back in between pin 6 and the taptation board
I'd say so. Nothing mentioned removing it. It could be vital.
jjanssen1
Hi,
I checked on the JMK PCB's taptation implementation guide and it says to not connect the resistor next to pin six and solder the wire directly onto the pin 6 of the PT2399. It also said to not connect the time pot.
Hope this helps
Joshua
P.S here's the link
jmkpcbs.com/wp-content/uploads/2014/03/Taptation-Implementation-Document.pdf
brand0nized
Thanks for checking, Joshua, I didn't realize the JMK doc mentioned the a Cave Dweller specifically. Well, that leaves me back at square one
