This is slowly coming together. I had bad luck with the enclosure twice - it broke where I drilled the last hole (last picture, bottom left) and it had a "belly", so the toner for the lion did not stick to the enclosure (I realized before etching and covered that area with tape). Anyway, first time I did a (partly) reverse etch. This one will be treated hard, so I use it as it is.
The PCB is my take on a tillman booster, ROG Condor Cab Sim, a ROG ruby amp, a MXR MicroAmp, and a mixer all in one. I will use it to practice with headphones, blend in backing tracks, slave-power other effects, blend two cell phones for small parties, record with cab sim, drive a 1x12" cabinet (actually gets quite loud!) etc. It will work with a battery as well. The footswitch can shut off one channel (e.g. if I blend in a metronome and want to mute it temporarily).
If you dig it, I still have sample PCBs and a build documentation available...
