Verifying ALL Etcher's Paradise projects
Started by alparent, February 16, 2016, 04:14:26 AM
storyboardist
I use the yellow stuff too and have had far better results with it than the blue press 'n peel (overpriced crap imho).
Guy behind Effects Layouts
gül
blearyeyes
Well Gosh! I just got some of that overpriced crappy Blue Press and Peel.
It is pretty expensive.
Haven't done any etching before.
What is the yellow stuff you're talking about?
playpunk
This thread is all of the good kinds of crazy I love on this board.
"my legend grows" - playpunk
alparent
OK, Since I didn't have do deal with snow today, got more time to do what I like.
After davent suggested the lacquer instead of the liquid tin plating. I decided to also try other things to protect the copper side from oxidizing .
I tried:
1. Fast drying acrylic satin clear: Smells good, dries in 1 min = Solders not to bad but will need to compare to others.
2. Polyurethane satin clear:  Don't know......not dry yet!
3. Varathan Diamond gloss clear:  Don't know......not dry yet!
4. Future floor polish (this stuff is acrylic base): Smells good, dries in 1 min = Solders very easy (probably 'cause it's easier to apply a thin coat.)
5. Will have to purchase and try actual lacquer.
Will have to do one with tin plating like I usually do in order to do a good comparaison.
Not sure how well any of these will actually help with oxidation in the long run?
Started building the 424 and also the BFC. Will have to order soon, I'm running out of stuff!
I'm also taking build notes as I'm going along.
OK got to go.......the wife want's to watch TV now.
I'm French.......sorry for my bad Englishhhhhhh.
copachino
i got like a huge box with dupont soldermask, its quite amazing and easy to use, i you want to try i can send you some but im not so sure how long it can take since i live outside usa
Solder mask is to prevent the solder from going where you do not want it to go, you don't want that,  that's not what you're trying to do with the lacquer.
peterc
I use the Kontakt PCB protector SK10. It can take a day to dry but works beautifully
http://www.mantech.co.za/ProductInfo.aspx?Item=90M0056
Peter
Affiliation: bizzaraudio.com
alparent
Quote from: blearyeyes on February 18, 2016, 10:14:33 PM
Wouldn't say it's crappy.... Just an expensive product. (Google will give you all the info you need for your first etch.)
The yellow paper you can get on ebay for like 2$ for 10 sheets. Search for "toner heat transfer paper"
alparent
Quote from: copachino on February 19, 2016, 04:07:59 AM
From Honduras to Canada, postage might be pretty high?
But would like more info on it. You have a picture, a link or something?
copachino
#25
Quote from: alparent on February 19, 2016, 01:04:02 PM
since its just an envelope i dont think its too high but i will check out, its quite good but i dont use it anymore, i had a tutorial over here let check it out
EDIT:
here its the tutorial
http://www.madbeanpedals.com/forum/index.php?topic=15392.msg144910#msg144910
alparent
copachino
Quote from: alparent on February 19, 2016, 02:45:43 PM
Sure looks interesting.
i will cut some of the mask tonight and check out the shipping to canada tomorrow
stevie1556
I'm PIFing 17 sheets of the yellow heat toner transfer paper stuff to anyone in the UK/Europe. I've found a much easier way for me to create solder paste stencils so it's unlikely that I'll ever use the rest of the sheets.
Sent from my SM-G928F using Tapatalk
alparent
