Author Topic: Aquaboy DLX problems  (Read 3145 times)
Orbis_Ignis
  • Stompbox Star
Re: Aquaboy DLX problems
« Reply #15 on: April 13, 2016, 07:53:12 AM »
Tracked it down to the cancel trimmer. Reflowed the solder and now I get correct voltages on both q3&4. Still no delay. The audio is coming out of pin 3&4 of the bbd, but I'm not getting any audio out of the cancel trimmer. Setting the trimmer halfway my voltages on all 3 pins is 3.3v
Edit: I was looking at the schematic wrong. Looks like I need to probe between ic3&4
« Last Edit: April 13, 2016, 07:58:49 AM by Orbis_Ignis »
Orbis_Ignis
  • Stompbox Star
« Reply #16 on: April 13, 2016, 08:36:24 AM »
Well, now I'm just getting clock noise on pins 3&4 of the first bbd and it goes all the way to pin 7 of the second bbd :-\
dannoceti
  • Stompbox Star
« Reply #17 on: April 13, 2016, 09:16:38 AM »
Are you sure you are biasing correctly? I used a fequency analyzer iPhone app to determine the clock fequency when audio probing pin2 of IC5. Set the clock to around 6.5khz, then audio probe the first BBD on pin 3.  What I didn't realize first time around was that bias trimmer 1 will be almost completely clockwise to pass delay.
Orbis_Ignis
  • Stompbox Star
« Reply #18 on: April 13, 2016, 09:46:43 AM »
Can't bias it. I'm not getting any repeats on pins 3 or 4. Just clock noise. My clock is set at 6.5 Hz, which is fully clock wise on the trimmer
Edit: Just checked again and the lowest I can get the clock is 7.2kHz
« Last Edit: April 13, 2016, 10:26:23 AM by Orbis_Ignis »
Orbis_Ignis
  • Stompbox Star
« Reply #19 on: April 13, 2016, 11:14:22 AM »
Turn the clock up to 11.48kHz. I can get delay but only with both bbd's in. So I can't bias it like the dock says. Should I be looking at C33 and possibly changing it
Orbis_Ignis
  • Stompbox Star
« Reply #20 on: April 13, 2016, 12:40:00 PM »
alrighty....I got this bad boy working. I couldn't bias it without both bbd's in. I also changed out C33 to a 150pF, even though my other was measuring at 117pF. That made a huge difference in the clock trimmer, which gave me a huge range to work with. Everything is biased and now I just need to make an enclosure for it. :)
  • skilled electronics ninja master
  • Cody - Fresno CA USA
    • My Blog
« Reply #21 on: April 13, 2016, 12:43:05 PM »
Thats awesome news.. way to stick with it man!
Martan
  • Solder Ninja
  • Marty
« Reply #22 on: April 13, 2016, 02:17:05 PM »
Way to go!
Orbis_Ignis
  • Stompbox Star
« Reply #23 on: April 13, 2016, 03:46:23 PM »
Thanks guys! I guess I should also mention that I had to use my audio probe to bias the two bbd's. I would get any delay out until I biased both of them. Now I have a sweet sounding delay with very long delay time. Can't wait to get this thing boxed up.
