Author Topic: Capacitor Conversion?  (Read 6709 times)
PaxWorks
  • Transistor Tickler
    • View Profile
« on: July 29, 2011, 11:39:53 AM »
Ok so I am still trying to understand the whole conversion concept for capacitors. You know uf to nf etc. I'm lookinng at the conversion chart here http://www.justradios.com/uFnFpF.html. I'm trying to find 10uf, I don't see ithere. Is there another conversion I need to do?
Does anybody have a simple method I could use to convert caps?
stecykmi
  • Electron Doctor
  • Misha
    • View Profile
Re: Capacitor Conversion?
« Reply #1 on: July 29, 2011, 11:46:29 AM »
10uF is fairly large value, so it's not typically written in smaller units. If you wanted to do it, you just need to move the decimal point over 3 times to write it in nF, and another 3 (6 total) to write it in pF.
10uF
10000nF
1000000pF
that's quite a lot of zeros, so you can see why uF are preferred in this case.
very occasionally, you may see it written in mF, which is a larger unit than uF, 0.01mF. Be careful if you're ever browsing smallbear, they incorrectly write uF as mF for some reason.
PaxWorks
    • View Profile
« Reply #2 on: July 29, 2011, 01:26:41 PM »
Thanks! I have a hard time trying to find caps on small bears website.
So would 10uf be listed as 10mf?
k.rock!
  • Electron Doctor
  • Kaleb
    • View Profile
« Reply #3 on: July 29, 2011, 01:34:13 PM »
At the Smallbear website, yes. The 'm' usually means 'milli' but when it comes to capacitors, it's uncommon to see milliFarads so in our application would mean microFarads (which should be the letter 'mu')
-Kaleb
mgwhit
  • Electron Doctor
  • Matt
    • View Profile
« Reply #4 on: July 29, 2011, 04:17:10 PM »
Micro = Greek character mu, which looks like this: μ, but is a pain to type.  That's why, by convention, everyone (except Smallbear) uses the lowercase u.
  • Global Moderator
  • Electron Doctor
  • Jacob - SK, Canada
    • View Profile
    • JMK PCBs
« Reply #5 on: August 05, 2011, 12:38:02 PM »
1000pf = 1nf
1000nf = 1uF
That's always helpful as well. I prefer 3nF to 0.003uF personally. The decimals can get all complicated, so I try hard to just use nf designations.
PaxWorks
    • View Profile
« Reply #6 on: August 05, 2011, 01:59:20 PM »
Ok  so currently trying to get together the parts for a serendipity build. Are these the right Caps from smallbear?
C1                     0.47mf  http://www.smallbearelec.com/Detail.bok?no=167
C2                     100pf    http://www.smallbearelec.com/Detail.bok?no=969
C3                     0.1mf    http://www.smallbearelec.com/Detail.bok?no=976
C4                     3300pf  http://www.smallbearelec.com/Detail.bok?no=970
C5                     0.47mf  http://www.smallbearelec.com/Detail.bok?no=167
C6                     100mf   http://www.smallbearelec.com/Detail.bok?no=188
C7                     47mf     http://www.smallbearelec.com/Detail.bok?no=190
The mf thing is still confusing.
  • Electron Doctor
  • Josh
    • View Profile
    • 1776 effects
« Reply #7 on: August 05, 2011, 02:34:59 PM »
Use a poly film for c4 .0033 mF
http://www.smallbearelec.com/Detail.bok?no=890
Also remember with those electrolytics, they are only rated to 16v.  Just an FYI if you ever wanted to run the pedal at 18v you'd be above their rated spec.
Josh
« Last Edit: August 05, 2011, 02:39:50 PM by gtr2 »
PaxWorks
    • View Profile
« Reply #8 on: August 05, 2011, 05:10:33 PM »
Thanks! Should I go with polyfilm?
  • Electron Doctor
  • Josh
    • View Profile
    • 1776 effects
« Reply #9 on: August 05, 2011, 05:29:15 PM »
Sorry, I don't really understand the question.  If you're referring to using poly rather than electrolytic caps.  The answer is no.  You can source out higher volt rated caps other places if needed.  I don't usually power drives at 18v but I like knowing I could...as long as everything else is rated accordingly.
Josh
Fastocker
  • Jim
    • View Profile
« Reply #10 on: August 05, 2011, 06:04:09 PM »
Here's an excellent conversion table for capacitors --- I printed it out and posted it above my workbench for quick reference.
Owner of Unique-Vibe, LLC
www.facebook.com/uniquevibe
bigmufffuzzwizz
  • Electron Doctor
  • Magic S.
    • View Profile
    • Magic Pedals
« Reply #11 on: August 06, 2011, 12:34:15 AM »
Practice, practice practice! You'll get it soon enough!
