Author Topic: Sprout fuzz working but makes noise - help  (Read 3105 times)
Ettore_M
  • Hector - Athens, Greece
« on: September 07, 2011, 02:09:46 PM »
Hi there! Need help here!
I built a sprout fuzz on veroboard (the one with the parallel lines  ::))..
When I plug it in, it plays ok, but it makes noise in the background (when I don't play.. ;D).
I double-checked for bad joints, wiring, etc., but I did not find something wrong. Maybe the fault is in the layout I made, so I attached the layout I made on DIY LC. I'm noob in this program, so I hope it does not confuse you..
I hope I made you understand what's the problem.. ::)
If you need any extra information, tell me
Thanks!
-Hector-
[attachment deleted by admin]
« Last Edit: September 07, 2011, 03:47:45 PM by Ettore_M »
 - Culturejam
irmcdermott
  • Ian - Spring Hill, TN
Re: Sprout fuzz working but makes noise - help
« Reply #1 on: September 07, 2011, 05:47:54 PM »
Does it make noise when the pedal is on? In bypass? Or both? I haven't built the Sprout, but fuzz pedals in general can be noisy... even when you aren't playing. Unless it's like a Sabertooth and has that gate control, that may be normal. Maybe someone who has built one can chime in, but I'm going to say that it is because it a fuzz, and well, they are noisy.
  • Josh
    • 1776 effects
« Reply #2 on: September 07, 2011, 06:59:03 PM »
Is it in an enclosure or are you testing it out of box?
It will be pretty noisy unshielded.
Josh
Ettore_M
« Reply #3 on: September 08, 2011, 01:21:23 AM »
Josh
I wanted to tell you about that.. I haven't boxed it yet, because I prefered to follow Brian's rule. I thought that if I grounded the jacks, it wouldn't have a problem.. Do you think it's because of me not boxing it?
Now for the layout. Do you think it's right? It's the first time I do this..
 - Culturejam
  • Josh
    • 1776 effects
« Reply #4 on: September 08, 2011, 03:30:26 AM »
An unshielded fuzz circuit is going to be noisy.  Just grounding the jacks only completes the circuit so you get a signal.  Once in the enclosure the jacks ground through the enclosure and help shield the effect.
Josh
Ettore_M
« Reply #5 on: September 08, 2011, 03:33:43 AM »
Josh
Aha.. I understand.. Thanks, Josh!!! ;D
Hector
 - Culturejam
Ettore_M
« Reply #6 on: September 08, 2011, 03:36:10 AM »
But can anyone tell me if the layout is right? I want to know if I do it the right way..  ;D
Thanks!
Hector
 - Culturejam
irmcdermott
« Reply #7 on: September 08, 2011, 08:46:12 AM »
From a quick glance, it looks like everything is connected correctly. You could probably trim down the layout a bit. I've only ever done one vero layout/build, so maybe someone else will catch something, but it looks correct to me. If you want, you can just wire lug 2 of the pot straight to the output jack and not run the wire to the board first.
Ettore_M
« Reply #8 on: September 08, 2011, 10:02:36 AM »
ok. I'll do that.. But do you think that the bigger layout will cause problems in the sound?
 - Culturejam
irmcdermott
« Reply #9 on: September 08, 2011, 10:05:57 AM »
not at all
Ettore_M
« Reply #10 on: September 09, 2011, 12:55:31 AM »
 - Culturejam
dwstanford
  • Solder Ninja
  • Danny
« Reply #11 on: September 09, 2011, 07:45:31 AM »
Yeah, i would try boxing it up, but not soldering the connections down until you are sure.  With a fuzz build, you will definitely get some background noise even when in the enclosure, but it will be more pronounced out of the box.  The layout shouldnt make a difference sinc there is such a low part count.  A more complicated build would benefit from being cut down, but yours should be fine.  Ive built this circuit a few times and it will have some noise, but isnt overly noisy.  Good luck.
Ettore_M
« Reply #12 on: September 09, 2011, 08:52:30 AM »
Thanks for the help, guys! I wired it up and boxed it in a can box.. It has some noise, but I don't care.. I like it very much and I'm so excited with the result.. I'll post photos and sound samples in the "build reports" when I find some time. Well, thanks again! ;D
 - Culturejam
dwstanford
  • Solder Ninja
  • Danny
« Reply #13 on: September 09, 2011, 09:20:49 AM »
Im glad you like it.  Be sure to post some sounds.  Id like to hear it.
Ettore_M
« Reply #14 on: September 09, 2011, 01:45:26 PM »
You bet I will... ;D
 - Culturejam
