Aquaboy Big Problem - Need Help (FAKE MN3101-Solved)
Started by mickey.bellinello, August 05, 2018, 08:54:01 AM
mickey.bellinello
Hi to all!
I'm Mickey and I've got problems with my Aquaboy.
I've built a lot of pedals so I'm not a newbie. I also done a Deluxe Memory Man delay clone so this isn't the first time I build an analog delay.
The problem is that I got no delay! In bypass mode I get dry sound, when the pedal is engaged I'v got dry sound too. If I turn the knobs no results at all.
If I use a probe to test pin 3/4 of IC3 I only listen a "whii" sound.
I built it yesterday and today I've made some measurement.
Here's the results:
IC1
PIN1 - 4.5
PIN2 - 4.5
PIN3 - 4.5
PIN4 - 0
PIN5 - 4.5
PIN6 - 4.5
PIN7 - 4.5
PIN8 - 9
IC2
PIN1 - 0.85
PIN2 - 1.8
PIN3 - 1.8
PIN4 - 0
PIN5 - 1.8
PIN6 - 1.8
PIN7 - 2.8
PIN8 - 1.8
PIN9 - 1.8
PIN10 - 3
PIN11 - 3
PIN12 - 1.8
PIN13 - 9
PIN14 - 1.8
PIN15 - 1.8
PIN16 - 0.08
IC3
PIN1 - 8.9
PIN2 - 3.99
PIN3 - 6.77
PIN4 - 6.77
PIN5 - 0
PIN6 - 3.95
PIN7 - 4.26
PIN8 - 7.77
IC5
PIN1 - 8.33
PIN2 - 3.95
PIN3 - 0
PIN4 - 3.99
PIN5 - 4.09
PIN6 - 4.15
PIN7 - 4.12
PIN8 - 7.77
The delay chip is an Xvive 3005
The Clock is an MN3101
The Compander is a CoolAudio V571D (I also tried a genuine Panasonic NE570, same results)
As You see I have some very wrong Voltage (I marked the most extreme in red)...
Can someone help me please?
Thanks So Much!
Did you audio probe your compander output? It's biased too low, probably the problem.
mickey.bellinello
Thanks for Your reply!
I just probe the compander pin7 (OUT1) and I've got signal.
Which parts of the circuits do I check? I'm afraid of PIN8 on both IC3 and IC5. As reference the v must be 0.59, I've got 7.77 on both.
Right you are, for some reason I was thinking you'd built the 3205 version.
Where did you get the 3101? I wonder if it's a relabelled 3102.
mickey.bellinello
Don't know that there are also a 3205 version.
I bought the pcb directly from Madbean. For the building info I refer to the suggested manual. The Pcb is the blue one, the 2016 version I think.
The 3101 has been bought from Musikding.de site and I don't think it's a fake.. all components came from musikding/banzai so I believe they're genuine..
Are there anything I can do to make it works?
mickey.bellinello
Here's a picture of the board:
In case of it would helps...
zombiesonore
Hi there.
What I see is that IC5 doesn't produce the good Vgg. And as it get the right voltage on pin 1, I'll check every components attached to IC5: C29 first, R40/41/42, C30, Trimmer and Delay Pot. maybe D2 too?
I guess you don't have any other mn3101 for testing?
mickey.bellinello
Hi!
Following your instruction I replaced c30 and c29 with new cap. r40/41/42 are the right value.
Trimmers seem to work. The delay pot is brand new Alpha so I think the problem isn't in it.
I haven't checked D2.
I make a check and the situation is the same. Unfortunately I have only one MN3101.
Do you suggest me to directly buy another one or the problem can be in some other areas of the circuit? Thanks So!
zombiesonore
Scruffie is the real guy about BDD circuit so I'll wait his input.
To the limit of my knowledge, I see that IC5 have only one input (pin 1 - Vdd) and it gives 2 important signals: CP1/2 & Vgg.
IC3 cannot works with a bad Vgg and yours his way too high. And it seems that IC5 have a good input Vdd so I guess the problem is with it.
It happen to simply have bad mn3101 even with a good source like banzai or musikding, it happened to me.
If you can't buy another one, and if you are in Europe, I can send you one for test purpose.
You MN3101 is actually an MN3102. How do I know? MN3102 produces the correct Vgg voltage for the MN3205 without any external circuitry. The correct Vgg voltage for an MN3205 is 14/15 of Vd.
Your voltages: 8.33Vd, 7.77Vgg
8.33 * 14/15 is 7.77!
This trick might work or it might not: ground pin 8 of your fake MN3101 to see if you can get delay out of the MN3005. If not, get yourself an genuine MN3101 and your problem should be solved.
Quote from: madbean on August 05, 2018, 01:09:17 PM
You MN3101 is actually and MN3102. How do I know? MN3102 produces the correct Vgg voltage for the MN3205 without any external circuitry. The correct Vgg voltage for an MN3205 is 14/15 of Vd.
BTW: the correct Vgg voltage for the MN3101 in this case should be Vd*(1-14/15) = 8.33*0.067 = 0.56v
mickey.bellinello
Thanks so much!!!
I never thought that a serious supplier can have fake goods.
I've ordered from another supplier a new mn chip. It will arrive mid week.
I'll try it with it and I'll tell You.
Zombiesonore I really appreciate your offer. I'll try the new chip and I'll tell you if your chip is needed. I live in Italy (Europe). And thanks so much again
I just grabbed a MN3101 from my parts box and the voltage divider is made from a 14.5k & 1.2k resistor... so you could put a 100R resistor from pin 8 to pin 3 of the '3101' to get the right voltage.
mickey.bellinello
Thanks So Much Scruffie! I've just soldered a 100R between pin 3 and 8 of the mn3101.
This evening I'll give a test.  ;)
mickey.bellinello
Here I am!
I tried soldering the 100R. The check at pin 8 is +-0.6V.
I tried to probe the mn3005 output but there are the same wiiii sound.
By the end of the week I'll receive a genuine mn 3101 ( I asked to the supplier and it has confirmed that is genuine.Let' hope!).
I'll update You soon and thanks again for support!
