OD->Boost and Boost->OD switch
Started by helos, May 02, 2019, 05:32:18 PM
helos
Hi guys! I'm sure you can help... I'm trying to design a pedal with an overdrive and a boost, each one with their switch.
But I'd like to add a toogle switch to choose the position of the boost (before or after the drive), much like the Fulltone Fulldrive 3...
Do you have a schematic for something like this??
Can someone help me?  :-[
Thanks
Aentons
Quote from: helos on May 02, 2019, 05:32:18 PM
Thanks
You are just talking about switching the order of the effects. Try and Google "Order Switch" or "series order switching"
Aentons
helos
Quote from: Aentons on May 02, 2019, 05:48:59 PM
Here is one I had saved
Awsome!! Thanks! So basically I should use a 4pdt toogle switch right?
Aentons
#5
Nope, sorry, that first one was probably confusing.
This should work better
http://www.geofex.com/article_folders/fxswitchr/fxswitchr.htm
Timko
Quote from: dan.schumaker on May 02, 2019, 06:52:31 PM
You can also get by with a 3PDT
I've used this one before on a few builds!
This is one is mine. It uses a 4PDT because it has a send-return in the middle with switched jacks. This way you can put other effects in between and still switch the order. if you don't want to use this, you're better off with a 3pdt.
