Gudday all, here's Wolverine, my build of a BE-OD on a prototype Madbean pcb that I won in a PIF from Brian a couple of years ago.
In case you missed the earlier posts, it's a tayda pre-drilled, powdercoated, UV printed enclosure. If you have a build you definitely want to box, these are great but need the power jack drilled out for the usual jack, and the LED hole is 4mm ( think - it was too big for a 3mm LED) , so it needed drilling out for a 5mm. Might work for a 3mm w/ plastic bezel. As luck would have it, the Pedalpcb predrilled enclosure was a perfect fit for the MB template.
Took a while for the box to arrive (cheapest postage this time), but not needing to drill, prime, sticker, clear the box makes the wait worthwhile. It appears the text is a little blurred, and my gain label is a bit off center. That's probably a limitation of the printer, combined with a vectored file. Or it could be something I did. The off center text is definitely my fault.
Sounds great, but it has a bit of a whistle at the higher gain levels that disappears with a buffered pedal in front, so I'll drop one in tomorrow night.
