Author Topic: Soulfull Drive  (Read 298 times)
  • Stephan Nelson / New Zealand / Aotearoa
Soulfull Drive
« on: August 17, 2020, 12:04:29 AM »
Based on Aion FX Thulcandra schematic, this is an adaptation of Xotic Sould Driven Allan Hinds signature drive. Aion changed the interal dip switches with a bass pot which makes a whole lotta sense.
Another great overdrive in the box... which one to play today...
  • Global Moderator
  • Jimi Lee
Re: Soulfull Drive
« Reply #1 on: August 17, 2020, 07:20:48 AM »
  • Felix - Graz, Austria
    • My blog - in german
Re: Soulfull Drive
« Reply #2 on: August 18, 2020, 10:51:52 AM »
you've really got your style dialed in! I could identify your builds anytime (even without the top screw-technique).
lovely build as usual!
My build docs
My etching tutorial
Re: Soulfull Drive
« Reply #3 on: August 18, 2020, 03:08:34 PM »
Cheers guys! Plyed it loud last night first time at band practise and liked it a lot. Great circuit, nice fat sounds and still defined.
Boba7
Re: Soulfull Drive
« Reply #4 on: August 19, 2020, 08:57:44 AM »
Your builds are always amazing. I like that you added the relay bypass circuitry directly to the pcb. Is it pic based by the way? I guess so.
And what company do you use to print your pcbs? Iíve had good experiences with Seeed and of course Osh park.
Anyways, great build as usual!
Re: Soulfull Drive
« Reply #5 on: August 19, 2020, 02:23:40 PM »
Cheers Boba! Yes relay bypass is PIC based, check out this great work and write up and it has the code as well:
https://www.coda-effects.com/2016/04/relay-bypass-conception-and-relay.html
I have just relatively recently started designing pcbs again after doing it some years ago with Eagle. I'm now using Diptrace and I'm lovin' it, works a lot more intuitive and efficient for me.
PCBs I get done with
https://jlcpcb.com/
two batches  so far and good experience, relatively fast turn around and boards seems just fine.
