Tagboard jfet tester.
Started by jman77, September 17, 2021, 10:08:10 AM
jman77
I'm getting into understanding jfets. Found runoffgrooves jfet schematic that tests for Idss and Vp. Now there are two designs up on tagboard. One has a 47 uF cap, the other has that cap and an ic. These differ from the one I found from rog. Yet I can't find any info on why these components were added. So I was just wanting to figure out how to translate this schem to vero, the one from rog's article. http://www.runoffgroove.com/fetzervalve.html
Schematic for tester is at the bottom.
I've drawn it on paper but I don't know  if it is correct.
mauman
This gives some background, and includes a version with the cap and op amp.    http://geofex.com/Article_Folders/fetmatch/fetmatch.htm
jman77
That one is for measuring just vgss off. The ones I'm inquiring about are for measuring both Idss and vp.
mauman
This one will do both.  The schematic omits the -9V supply that's present on the vero, but that's just the TC1044 IC1, plus C1 and C2, feeding -9V to pin 4 of IC2.  You can use a second 9V battery for the -9V supply and simplify it.  Note that R1 (100 ohm) is 0.1% tolerance, not the usual 1%.
jman77
Quote from: mauman on September 18, 2021, 07:22:43 AM
So this vero is correct? I can build as shown and it'll work?
mauman
jman77
rauldlr
