Author Topic: Prototyping & Testing Rig Kit released  (Read 1462 times)
Timko
  • Electron Doctor
  • I'm walking a line, visiting houses in motion.
    • View Profile
Re: Prototyping & Testing Rig Kit released
« Reply #15 on: November 15, 2021, 01:57:56 PM »
This is what I've been wanting to build to go with my JMK Test Rig unit for complete circuits!  I'll be ordering one once they're back in stock.  Just in time for the design of V2 of the Kansas City Prairiemaster (complete with some sort of resonant filter).
harryklippton
  • Solder Ninja
  • Will
    • View Profile
« Reply #16 on: December 13, 2021, 09:37:28 PM »
I just put my kit together and it went smoothly. When it came time to affix the breadboards, I considered dual lock for a minute cuz that's what I had on hand, but I decided I didn't like how high it made the breadboards stick up and I wanted a firmer surface underneath. So I used an exacto to cut thin strips off the adhesive backing of the breadboards and stuck em down. If they ever need replaced, there's a lot less adhesive surface that way.
I'm gonna look for some mini grabbers to solder on to some jumpers with pins on the other side for hooking things up but I'm not sure how well that'll work out.
I also wanted to store it in the swanky black box the kit came in, but the lever on the 3pdt is just slightly too long to let the lid close nicely
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #17 on: December 13, 2021, 10:26:55 PM »
That's a fine idea and something I had not considered when sourcing everything. I think there will be a V2 at some point. One thing I plan to add for a future version is a power on/off switch. I'm actually kicking myself a bit now for not including that as a feature in this version.
Jaga
  • Diode Destroyer
    • View Profile
« Reply #18 on: December 16, 2021, 04:06:06 PM »
Could you please include a headphone out for V2, this would be a killer feature, because the amount of gear that should be switched on and plugged in would be the minimum possible :)
harryklippton
  • Solder Ninja
  • Will
    • View Profile
« Reply #19 on: January 08, 2022, 08:35:46 PM »
Got my first chance to try out the prototyping rig to test a build and it was great. My mini grabber to jumper pin leads worked exactly how I had hoped.
Big Monk
  • Diode Destroyer
    • View Profile
« Reply #20 on: January 10, 2022, 10:49:19 AM »
I've done this a few times with my Protoboard. Good way to "Rock before Box".
My name is Derek Scott. I can tell that we are gonna be friends.
“Didn’t realize you were a Titanius Giganticus...” - Feral Feline
"Beneath the bebop moon, I'm howling like a loon, for you..."
“You better watch out! There might be dogs about...”
Hirti
  • Transistor Tickler
    • View Profile
« Reply #21 on: January 13, 2022, 06:44:45 AM »
I also finished mine yesterday. I haven't used a breadboard in like 15 years. It was so much fun  ;D Built a LPB-1 into a Mythos Golden Fleece (Electra style circuit).
PedalJerk
  • Diode Destroyer
    • View Profile
« Reply #22 on: January 18, 2022, 12:00:54 AM »
Hey, Brian!
I just recently purchased the ProtoRig from you, but it appears that the audio probe has an issue. When I removed the threaded collar from the probe tip, there is no hole or any method that I can see of pushing the connector wire lead through from the plastic handle end. Am I missing something stupidly obvious? Everything else assembled and works perfectly. Thanks in advance for any reply.
