Author Topic: How to test a circuit with 2 footswitches?  (Read 1573 times)
Grazza
  • Diode Destroyer
« on: October 10, 2021, 01:08:48 AM »
Hi all, I have just finished soldering the components to the board of my first build and I am ready to test the circuit. However, this board has 2 switches (distortion and boost) so 2 input and 2 output wires. This might be a stupid question, but do I just connect both inputs to each other to the jack and both outputs together with the jack for the purpose of testing?
  • Matthew
Re: How to test a circuit with 2 footswitches?
« Reply #1 on: October 10, 2021, 01:42:14 AM »
Take the boost in and the boost out and hold them together with an alligator clip. Do the same for the distortion.  When you unclip them and desperate the wires it will “switch off” the effect.
Grazza
  • Diode Destroyer
« Reply #2 on: October 10, 2021, 01:59:15 AM »
So connect the distortion wires like it is a single effect and just complete the circuit of the boost with an alligator clip, then vise versa to test the boost? Is that what you mean?
  • Matthew
« Reply #3 on: October 10, 2021, 08:28:16 AM »
No wait, I was really tired I’m not sure I was thinking of this correctly. That is to say I’m pretty sure I wasn’t.  Why don’t you post a couple pictures or a link to the board or schematic you are using. That would help make things more clear.
Grazza
  • Diode Destroyer
« Reply #4 on: October 10, 2021, 05:47:02 PM »
It's the mad bean krankosaurus, from a very long time ago, version 3.5
Grazza
  • Diode Destroyer
« Reply #5 on: October 10, 2021, 05:50:07 PM »
https://www.madbeanpedals.com/projects/archives/index.html
It's in the archive, Im not home so can't take any photos of the board
mauman
  • Solder Ninja
  • Mike
« Reply #6 on: October 10, 2021, 06:55:48 PM »
Based on the build doc you linked, there are 2 independent circuits on the board.  Test them independently one at a time before you box them up (Dirt in to Dirt out, and Boost in to Boost out.)  The build doc shows how to wire the foot switches when you're ready to box it up.
Grazza
  • Diode Destroyer
« Reply #7 on: October 11, 2021, 01:22:48 AM »
Awesome thanks
