Do yourself a favor kid... Build a Madbean Moar
Started by matmosphere, November 17, 2021, 04:21:14 PM
Tremster
Ah, Les Savy Fav. Haven't listened in a long time, will do now.
My first thought was Built to Spill, though.
I will put the Even Moar on my list ...
287m
Moar is my favorite from MBP 1590G.
need build again for 1590B. hate doing this in 1590A perf.
Quote from: Tremster on November 19, 2021, 08:54:39 AM
They're one of my favorite bands. Their last album was really good.
Due to a big assist from AionFX I was finally able to figure out doing slotted pads for switches. Now hopefully this all works!
Quote from: madbean on December 02, 2021, 12:56:37 AM
What does slots instead of circles achieve, does it make the footprint smaller?
Quote from: jimilee on December 02, 2021, 01:17:19 AM
The only advantage is that it requires less solder to achieve a good joint. And, I think it looks more professional to have slotted holes to match the actual dimensions of solder lugs.
Actually, there's one other possible benefit - if you size everything right when you load the part in the board it will stick which makes soldering easier, rather than having to jerry-rig something to hold it in place.
Quote from: madbean on December 02, 2021, 01:29:58 AM
All valid points, thank you Wise and Knowledgeable Bean.
benny_profane
How were you able to do that in Eagle? I kept getting errors when trying to make pads like that. I ended up using DipTrace for the project that needed that footprint.
storyboardist
#23
Quote from: benny_profane on December 02, 2021, 03:31:08 PM
+1 I tried a couple years ago and had no luck.
Also I've been meaning to dig up my MOAR board since I moved a year ago. Just gotta find the right box. Loved the idea when I saw the schematic.
Guy behind Effects Layouts
