Author Topic: JD-9 single sided Oscillating issues  (Read 918 times)
  • Global Moderator
  • Jimi Lee
« on: July 04, 2023, 01:37:13 PM »
I made a layout for the Ibanez Jet Driver. It works, but I'm getting some oscillation in either the Drive or EQ section. I can't quite work it out. My voltages all look like they're supposed to. Any help is much appreciated.
« Last Edit: July 05, 2023, 05:36:17 PM by jimilee »
  • Global Moderator
  • Jimi Lee
Re: JD-9 single sided Oscillating issues
« Reply #1 on: July 05, 2023, 05:44:12 PM »
Just a bump to see if anyone can see something in the layout that would cause the oscillation.
mauman
  • Solder Ninja
  • Mike
« Reply #2 on: July 05, 2023, 06:19:22 PM »
I'm thinking you may have a too-long trace (adding too much inductance) connected to your lower op amp (EQ) pin 6 (inverting input.)  It runs all the way to the top of the board to pick up Mids pot 1 and Tone pot 1.  Feedback loops might need to be shorter than that, stray inductance or capacitance there can cause oscillation.
  • Global Moderator
  • Jimi Lee
« Reply #3 on: July 05, 2023, 09:37:52 PM »
That makes perfect sense; Iím still learning. I modified the original schematic, and now I think I know what it was the way it was. Thank you sir.
NorthCoast
  • Transistor Tickler
  • Aaron
« Reply #4 on: July 05, 2023, 10:20:42 PM »
Did you include C101?
The 47uf cap is C100, which is 100uf on the schematic, but I don't see a 47uf C101.
Also, it looks like there might be two traces that are touching that shouldn't; I've circled them in yellow:
"People discuss my art and pretend to understand as if it were necessary to understand..." - Claude Monet
  • Global Moderator
  • Jimi Lee
« Reply #5 on: July 06, 2023, 09:40:32 AM »
I checked with my meter, the traces arenít touching, so weíre good there. The 100uf is actually attached to my +9 and ground leads on my testing rig. That did kill a lot of the noise. Iím going to rework it with shorter traces in the top section, I think that might do it. I reworked the original schematic because it seemed to be all over the place, but it seems they may have been a reason for that madness.
