Capacitors Polarity...
Started by whyckicki, January 18, 2012, 03:44:46 PM
whyckicki
Hi,
I was wondering if i can use a polarized Cap instead of a non polarized one in the Slambox ?
If yes, in which sens ? Does the polarity still matters or not ?
When I bought my coponents I didn't pay attention to the non-polarity of the C1 (100nF)...
I know that's not a big question but i didn't find any thing about it and I'm in somewhat a very big noob in electronics, the Slambox is my first build.
Thank you.
jtn191
yes, as long as you're absolutely sure the values are the same--units and all. The physical size of the cap might limit you but if it'll fit on the board, it'll work  ;)
whyckicki
So that means that I can put the capacitor in any polarity ?
The value requested on the schematic is 100nF and I use 0.1uF... I think that's the same
jtn191
whyckicki
Ok thank you for you're help :)
I'll post picture once it's done !
ckim715
positive side of the electrolytic goes to the side of the higher voltage, iirc.
-Charlie
jimmybjj
Quote from: ckim715 on January 18, 2012, 04:35:31 PM
+1
Pcbs no longer available
sgmezei
whyckicki
Hum, higher voltage ok but on the schematic the capacitor is between the input and a nut...
http://www.madbeanpedals.com/projects/Slambox/docs/Slambox_ver.4.pdf
What kind of capacitor do you have? I've not heard of polarized 100nF caps before. Are you sure you have the right value?
whyckicki
At that point in the circuit, the capacitor is acting as a decoupler from the input to keep DC from interfering. I think the - would go towards the input.
whyckicki
So to be sure, that would make : Input .... [(-)Caps(+)]..... the nut
Not sure what you mean by nut. There's no nut in the circuit.
whyckicki
The rest of the circuit... but the polarity I shown was right or not ?
