Author Topic: Cosmopolitan problem: Low sound [SOLVED]  (Read 5016 times)
2tonewarrior
  • Transistor Tickler
« on: March 29, 2012, 12:16:16 PM »
Hi, Ive built a Cosmopolitan and it does sound, but not very much. The bypass works but when you switch on the effect, the volume is barely the same (or even lowder) as when in bypass (with ALL knobs set to max.) It sounds a little fuzzier and cracked, and the sound is very muffled.
Ive checked wiring, solder joints, Pot values,....
Tomorrow when i get my camera back i will post photos. I start this post today in case anyone has had the same problem and can help me
« Last Edit: April 02, 2012, 07:09:09 AM by 2tonewarrior »
k.rock!
  • Kaleb
Re: Cosmopolitan problem: Low sound
« Reply #1 on: March 29, 2012, 12:24:33 PM »
Check your transistor pinouts. Sometimes the base is not always in the middle pin. What transistors are you using? Maybe we can look for a datasheet.
-Kaleb
2tonewarrior
« Reply #2 on: March 29, 2012, 12:49:51 PM »
-Kaleb
BS170, BC109B and AC127
Ive double checked them. Im a little newbie in electronics so it could be wrong but I think the pinouts are ok, Ive take for reference this page http://www.kpsec.freeuk.com/components/tran.htm
The first time I connect the effect to the guitar the pinouts were back to front (I realized this later) Could I have burnt the transistors?
mgwhit
  • Matt
« Reply #3 on: March 29, 2012, 01:42:15 PM »
If it's not transistor pins (or the transistors themselves), check the values of R2, R3, R6 & R7 and confirm that they are Ohms and not Kilohms.  A Kilohm value in R2, R3 or R7 would result in significantly less gain/volume.  If that doesn't do it, yes, photos!  Good luck!
pryde
« Reply #4 on: March 29, 2012, 02:29:13 PM »
I had the EXACT same problem with my cosmo and the great folks here noticed I has the wrong capacitor value in C2. Triple-check ALL of your cap and resistor values. It sounds like you have a wrong value somewhere.
You are going to love this pedal when you get sorted!
2tonewarrior
« Reply #5 on: March 29, 2012, 03:20:32 PM »
Quote
All values are ok checked by code and multimeter.
Ive read you thread before posting this and double checked the values. Now triple checked it and all values seem to be correct. Maybe I am missing something because its true thats you problem is really similar.
EDIT: In my case the only pot that is working properly is volume. Gain rises the volume and a little gain in the last seventh of the turn. All the other pots seems to change slightly the sound.
Sorry for the poor english, Im getting more crazy trying to explain my problem than trying to resolve it. :)
« Last Edit: March 29, 2012, 03:33:01 PM by 2tonewarrior »
2tonewarrior
« Reply #6 on: March 30, 2012, 05:05:53 AM »
Photos!
Tell me if you need a photo of any specific part
cjkbug
  • cory
    • My Tattoo Shop
« Reply #7 on: March 30, 2012, 07:33:16 AM »
It looks like you have a .001uf for c11 instead of.100uf that's the 1st thing I saw I'll keep looking. and can we get some closeups of the whole solder side?
cjkbug
  • cory
    • My Tattoo Shop
« Reply #8 on: March 30, 2012, 07:36:28 AM »
c15 appears to be the same and c5 looks like a .022 instead of .220. I am gonna check the codes to be sure.
2tonewarrior
« Reply #9 on: March 30, 2012, 07:45:04 AM »
u1=0,1uF , isnt it?
And can we get some closeups of the whole solder side?
Ok, ill try but its difficult with the mounted pots.
Thanks for reply :)
2tonewarrior
« Reply #10 on: March 30, 2012, 07:47:01 AM »
cjkbug
  • cory
    • My Tattoo Shop
« Reply #11 on: March 30, 2012, 07:50:24 AM »
Also I've never seen a zener diode that looks like that the ones I usually get are the orange glass types.
The codes on your wimas  look to me like the values you used are off. I don't know how experianced you are so don't take it hard but I'm gonna see if I can find my conversion chart for pf nf uf.  I had a hard time understanding them at first.  basically 1000pf = 1nf = .001uf... it looks like your code 1k 63 would be 1k(1000) pf or 1n or .001uf with a maximum voltage rating of 63 volts.
Please someone weigh in if I am off track as I am not familiar with these particular codes. don't always assume the supplier put what you ordered in the little plastic bags. they screw up values all the time. it's pretty easily done.
cjkbug
  • cory
    • My Tattoo Shop
« Reply #12 on: March 30, 2012, 07:51:36 AM »
u1=0,1uF , isnt it?
Thanks for reply :)
1uf boxs caps are a lot bigger than that and would still be the wrong value
2tonewarrior
« Reply #13 on: March 30, 2012, 08:06:09 AM »
This is my zener diode http://www.banzaimusic.com/9-1V-Zener-Diode-5W.html, as a noob I ordered the 5W version  ::) but it should work well, shouldnt it?
According to this web http://www.wima.de/EN/marking.htm:
u1k63 = 0,1uF - Tolerance=10%(k) - 63V
mgwhit
  • Matt
« Reply #14 on: March 30, 2012, 08:07:06 AM »
Sorry, but you're off with the capacitor codes.  u1 = 0.1uF, K = 10% tolerance, 63 = 63V.
