Fuzz Face w/ volt converter under a $1 almost under ¢25... smd and 1590a content
Started by jimmybjj, July 18, 2012, 12:29:24 AM
jimmybjj
...See, under a dollar :) It was a TIGHT squeeze but its all there including the charge pump. All of the resistors are SMD on the back of the board, pointed out by the pen. Their is gold fleck in the green that matches the brass knobs. The knobs are spent brass from 40cal rounds. I didn't have any knobs laying around that worked with the pedal and the brass was on the bench, so i had a aha moment. Fuzz = cops, cops shoot bullets, maybe its a stretch :) Finish is dual stage powdercoating including the lettering.
I have a couple of extra boards is anyone is interested in trying smd. $6 shipped
Pcbs no longer available
greyscales
Those knobs... are killer.  ;)
Very cool all around. Those resistors are tiny.
Awesome all around.
The finish is indeed really spiffy. Is it just a powdercoat, or is there something else going on?
Fantastic.  The entire thing.
I may have to use the bullet knob idea if you don't mind.  What a great idea for 1590a builds.
GrindCustoms
Wow, looks perfect, everything gets nicely together.
I would take one of those board if you don't mind. 8)
Rej
pryde
HappyCircuits
That is really slick! I'd also be interested in a board if you still have any.
-A.P.
jimmybjj
Thanks for the compliment guys.
Quote from: gtr2 on July 18, 2012, 01:31:00 AM
Love the powdercoat work as well as the board!
Thanks! The board came out good except that stupid batch number they put right over the fuzz face label, its hard to see from the pics i posted.
Quote from: midwayfair on July 18, 2012, 01:51:07 AM
thanks, just powdercoat. applied one coat, vinyl mask, applied second coat, remove mask. The process is all about timing and getting the masking off before it melts.
Quote from: GrindCustoms on July 18, 2012, 02:04:09 AM
Quote from: HappyCircuits on July 18, 2012, 04:27:31 AM
Sure, I'll pm you.
jtn191
jimmybjj
Quote from: jtn191 on July 18, 2012, 04:33:49 PM
I'm interested in a board! Are those standard 16 mm pots?
Pm'd, yes they are standard 16mm pots. They are not board mounted. The holes are spaced for 9mm pots but I've never worked with 9mm pots so I'm not sure how that would work. The only pots I could find are the ones with tabs on the side. I don't know if those tabs need to grounded or what.
Quote from: jimmybjj on July 18, 2012, 04:49:16 PMThe holes are spaced for 9mm pots but I've never worked with 9mm pots so I'm not sure how that would work. The only pots I could find are the ones with tabs on the side. I don't know if those tabs need to grounded or what.
Smallbear has the kind with just three little PCB tabs. I think Das Musikding has them, too, at a reasonable price (E2.25) for everyone in Europe.
jimmybjj
Quote from: midwayfair on July 18, 2012, 07:21:42 PM
Thanks, I couldn't find the ones I want on there. I was specifically looking for the ones with right angle pins so I could board mount them, the ones with straight pins don't help much in this context.
