Drill template prints too small
Started by Tuxedo3, February 05, 2017, 07:24:23 PM
Tuxedo3
Very weird, each time I print a drill template it is just a bit too small. I measured the enclosure/PCB while in Photoshop and they are correct, but they are definitely not once printed. I have to print the file to a PDF before printing it (I'm at college) any thoughts on this?
neandrewthal
The only thing I can think of is when you are in the print preview make sure the box "actual size" is selected.
Tuxedo3
Stomptown
Did you download the PDF and open it in acrobat or did you open/print in your web browser? I have to actually downloaded ad the files to get the to print to the proper scale...
Which docs are you having trouble with?
Tuxedo3
Quote from: Stomptown on February 06, 2017, 12:15:55 AM
My main goal is to make a drill template for a pedal I designed, I've been using the template for a 1590B madbean pedal and kinda adjusted some things. I've done it before and it worked perfect.
Quote from: madbean on February 06, 2017, 12:22:08 AM
I have been using a 1590B template from one of your pedals but adjusted to fit the PCB I made. I tried printing one right from the site and it still printed odd. I think it might be a printer issue I'm just not sure.
Are you using Adobe Acrobat Reader to print it or are you using the PDF reader built into your browser?
Try both and see if you get the same results. Like mentioned, make sure no scaling is set.
Jebus
There might also be option called "fit to page". Take that off also. :)
AntKnee
What he said, on "actual size" setting.
Tuxedo3
This has been super helpful guys, thank you so much for the insight.
