Author Topic: Drill template prints too small  (Read 1191 times)
Tuxedo3
  • Stompbox Star
    • View Profile
« on: February 05, 2017, 01:24:23 PM »
Very weird, each time I print a drill template it is just a bit too small. I measured the enclosure/PCB while in Photoshop and they are correct, but they are definitely not once printed. I have to print the file to a PDF before printing it (I'm at college) any thoughts on this?
neandrewthal
  • Stompbox Star
    • View Profile
Re: Drill template prints too small
« Reply #1 on: February 05, 2017, 02:02:51 PM »
The only thing I can think of is when you are in the print preview make sure the box "actual size" is selected.
Tuxedo3
  • Stompbox Star
    • View Profile
« Reply #2 on: February 05, 2017, 03:52:16 PM »
Good thought, it is set to 100%.
Stomptown
  • Electron Doctor
  • Jon
    • View Profile
« Reply #3 on: February 05, 2017, 06:15:55 PM »
Did you download the PDF and open it in acrobat or did you open/print in your web browser? I have to actually downloaded ad the files to get the to print to the proper scale...
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #4 on: February 05, 2017, 06:22:08 PM »
Which docs are you having trouble with?
I own madbeanpedals (duh). I am part owner of Function F(X).
Tuxedo3
  • Stompbox Star
    • View Profile
« Reply #5 on: February 05, 2017, 07:08:45 PM »
My main goal is to make a drill template for a pedal I designed, I've been using the template for a 1590B madbean pedal and kinda adjusted some things. I've done it before and it worked perfect.
I have been using a 1590B template from one of your pedals but adjusted to fit the PCB I made. I tried printing one right from the site and it still printed odd. I think it might be a printer issue I'm just not sure.
  • skilled electronics ninja master
  • Electron Doctor
  • Cody - Fresno CA USA
    • View Profile
    • My Blog
« Reply #6 on: February 06, 2017, 11:00:18 AM »
Are you using Adobe Acrobat Reader to print it or are you using the PDF reader built into your browser?
Try both and see if you get the same results. Like mentioned, make sure no scaling is set.
Jebus
  • Solder Ninja
  • Kalle
    • View Profile
« Reply #7 on: February 07, 2017, 03:04:28 AM »
There might also be option called "fit to page". Take that off also. :)
AntKnee
  • Electron Doctor
  • Anthony
    • View Profile
« Reply #8 on: February 08, 2017, 07:35:02 PM »
What he said, on "actual size" setting.
Tuxedo3
  • Stompbox Star
    • View Profile
« Reply #9 on: February 09, 2017, 05:59:52 PM »
This has been super helpful guys, thank you so much for the insight.
