Author Topic: 10.27 - Pre-Ordering available  (Read 18677 times)
andersom
  • Diode Destroyer
    • View Profile
Re: 10.27 - Pre-Ordering available
« Reply #15 on: October 28, 2011, 01:08:37 AM »
Order placed :) Thanks
  • Electron Doctor
  • John - Wakefield, UK
    • View Profile
    • Juan's Gnomepage
« Reply #16 on: October 28, 2011, 01:36:54 AM »
One thing I forgot to mention in the announcement: The DirtBag and HoneyDripper will run off 9v, however, if you are building the MN3005 version of the DirtBag (v3205 only works at 9v) you will want to use a charge pump and 15v regulator. With the HoneyDripper, I'm re-designing the stock power supply based on experimenting with my build. I found that it sounds best at 12-15v. So, I will recommend a charge pump for that as well. Not a plug to sell more "Road Rages" but some may appreciate having this info in advance!
The Dipthonizer uses an 18v supply in the stock unit and then knocks it down to 10v via Zeners, but I found this to be incredibly inefficient in my build. Using a regulated 12 or 15v supply and a voltage divider instead of the Zeners kept the voltages rock solid under load.
Will be interesting to see how the HoneyDripper compares to my Dipthonizer clone in that respect (which also uses a road rage... They get around those little boards!).
“I excite very large doom for days” - playpunk
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #17 on: October 28, 2011, 04:36:05 AM »
hey brian, are there many slow loris's left? Its gonna be a while until i get back into building
Plenty, ATM.
No matter where you go, there I am. Watching you.
ramengo
  • Diode Destroyer
    • View Profile
« Reply #18 on: October 28, 2011, 07:19:40 AM »
HI,
this is my 1st message..
sorry for my bad english..
i want to know the component of the dirtbag deluxe and the current lover..
because i have to do the order by e-commerce
when i can view the pdf file??
thanks for the reply..
Angelo
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #19 on: October 28, 2011, 07:23:15 AM »
ramengo, I'll have this available this weekend.
ckim715
  • Solder Ninja
    • View Profile
« Reply #20 on: October 30, 2011, 11:01:15 AM »
What size is the PCB for the dirtbag? Trying to get a couple of the little things like the enclosure taken care of :)
-Charlie
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #21 on: October 30, 2011, 11:06:09 AM »
The Dirtbag fits into a 1590BB in the vertical orientation  :)
The HoneyDripper and Current Lover require a 125B.
tenwatt
  • Solder Ninja
  • Jeremy
    • View Profile
« Reply #22 on: October 31, 2011, 06:10:31 AM »
You're such a tease...  ;)
I've been checking all weekend.  Can't hardly wait.
Not too bright....
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #23 on: October 31, 2011, 04:26:30 PM »
Here are the BOMs for the Current Lover, Honey Dripper and Dirtbag Deluxe.
The Honey Dripper no longer requires an extra Road Rage board: I was able to incorporate the circuitry onto the a revised layout. The parts needed for the RR portion are included in the HoneyDripper BOM. The Dirtbag still requires a Road Rage IF you are building the MN3005 version. These are not included in the Dirtbag BOM.
« Last Edit: November 01, 2011, 09:37:58 AM by madbean »
  • Electron Doctor
  • Corey - Christchurch, NZ
    • View Profile
    • Soundcloud
« Reply #24 on: October 31, 2011, 04:42:53 PM »
Woah... seeing that Dirtbag board is making me flip out! :o :D
I need a bigger pedalboard!!! :P
Haberdasher
  • Electron Doctor
  • "El Duder-ino"
    • View Profile
« Reply #25 on: October 31, 2011, 04:54:54 PM »
Awesome
Is 25V and > good for all the dirtbag caps or should we go with 35V and >?
Are the pots on all three of these pc mount?
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #26 on: October 31, 2011, 05:20:29 PM »
25v is the most you need. Everything is PCB mounted.
thatirishsob
  • Transistor Tickler
  • Sean O'Bryan
    • View Profile
« Reply #27 on: October 31, 2011, 05:38:52 PM »
WOOHOO thanks a lot Brian!!!
djaaz
  • Solder Ninja
    • View Profile
« Reply #28 on: October 31, 2011, 08:10:51 PM »
Looking at the current lover & dirtbag deluxe, is it safe to assume that any cap above 1uf is polarized?
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #29 on: October 31, 2011, 09:26:23 PM »
Yes. IIRC, all the 1uFs are polarized, too.
