Author Topic: Effectslayouts.com Heartbreaker Overdrive  (Read 678 times)
  • Dan
« on: June 03, 2021, 12:50:22 PM »
I have been editing my balls off and noticed this little gem in the background. I can't seem to find where it went on the website but this thing gave me hell. thesameage had a post about desoldering blues and this thing put me down for about 3 days!
I foolishly did not get long pin pots and soldered in the board the wrong way. It was a demon of a bad idea on my part. So here it is warts and all, jumpers to get it to work and just a fly in the ointment.
It does sound really great though and I love the copper airbrush front with little monkey.
  • Chris
Re: Effectslayouts.com Heartbreaker Overdrive
« Reply #1 on: June 03, 2021, 12:58:38 PM »
We've all been there. Good save!
  • Global Moderator
  • Jimi Lee
« Reply #2 on: June 03, 2021, 02:15:08 PM »
That looks spectacular. I canít say I havenít done that myself. What is it exactly?
« Last Edit: June 03, 2021, 02:20:19 PM by jimilee »
  • Dan
« Reply #3 on: June 03, 2021, 02:44:04 PM »
It is a half red llama half tube screamer ish sort of thing. I wish it was still available because it does sound really good.
  • Global Moderator
  • Jimi Lee
« Reply #4 on: June 03, 2021, 03:41:39 PM »
He has a similar board on there, itís his take on the JHS double barrel. Half morning glory half tube screamer.
TeleCrunch
  • Diode Destroyer
« Reply #5 on: June 04, 2021, 08:06:56 AM »
Nice color combo and custom artwork.
I have the build doc and I did the same damn thing - had to remove and replace all the pots. I've been trying to figure out how to add a switch to reverse the order of the effects to send the Screamer block into the Llama instead of the existing order as an option.
No Squid Pro Quo
Feral Feline
  • Transistor Tickler
« Reply #6 on: June 04, 2021, 05:21:42 PM »
Your pain is my gain, thank you for posting.
I've got the board, DULY NOTED re POTS etc.
Didn't realise the board's discontinued, and didn't realise long-legged pots are required.
I think the footswitches will suffice in holding the board in place, I can just use lugged pots with cap-lead clippings or offboard wiring...
For anyone interested in this thing, it's basically a Way Huge Camel Toe, but the 808 side is a ROG UBE-Screamer minus the buffer and clean signal (not enough inverters left over after using some up for the Llama).
So if you build a Llama and an Ube-screamer separately then chuck'm in the same box, you've got it AND you'd have the clean blend (great for bass, still good for guitar).
