Autobahn
Started by TreeSlayer, February 07, 2013, 03:58:49 AM
do you check for solder bridges with a magnifying glass? I had this same issue and turns out there was a bridge on the wire going to one of the pots
Double check to make sure you didn't miss a jumper under the ic.
Also you can sometimes fry a backwards part or damage during removal.  So when you reverse and replace, doesn't work for a different reason.
I just spent 2 hours last night troubleshooting a sho'nuff v2 pcb.  Actually a very simple circuit but I had to actually ohm it out.  First an open circuit diode, and then a bad trace to the bypass mode at the on board 3pdt.
Mind you I built a cavedweller and slow loris earlier in the week with no issue..!
Good luck!
blue_tokai
Quote from: jimilee on February 09, 2013, 01:01:49 AM
+1
Easy to have a solder bridge here. I've experienced similar on another build. Sometimes the bridge is so good, it looks like it actually belongs ;) (doh)
Recent builds.....
Sea Urchin, Cave Dweller, Autobahn, Little Angel, Tremulus Lune
TreeSlayer
sorry, guys! the girls took me to dinner tonight. i mean hey, wouldn't y'all go out with the soft tails instead of talkin to a bunch of hard tails? ;{D
"At the line it's just you, me and the tree." the TreeSlayer
"You have the rest of your life to make excuses and be a fuckin' pussy. Today is your day OFF!"  Amiri King
TreeSlayer
yup, but i'm goin over it for the fourth time. i think now that's my problem...
TreeSlayer
Quote from: wgc on February 09, 2013, 01:13:15 AM
Good luck!
i've had so much trouble that the only thing i don't socket is resistors and diodes, and caps i know have a lot of space between other parts.
Quote from: TreeSlayer on February 09, 2013, 03:14:35 AM
+1
Haberdasher
reflow all your solder joints.  with all those sockets in there i could see having a dead one.
this circuit is kind of weird too.  if you're using low output pickups you really have to find the sweet spot on the sensitivity knob to get the groovies.
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
Hoping to get mine boxed finally this weekend
blue_tokai
Quote from: jimilee on February 09, 2013, 03:50:43 AM
Just pulled the guts out of the box mine was in so I could paint and decal up the box. Something to do during the snow storm :P
Recent builds.....
Quote from: TreeSlayer on February 09, 2013, 03:20:07 AM
Just want to be clear:
Try a new part if you had it backwards, the original may be trashed when powered up backwards.
Don't forget to check the jumpers
TreeSlayer
lookin forward to seein it!
TreeSlayer
Quote from: wgc on February 09, 2013, 01:46:50 PM
cap tested good. all five jumpers are in.
TreeSlayer
Quote from: Haberdasher on February 09, 2013, 03:43:30 AM
even though they look good, i think it's worth a shot to reflow. runnin Seymour Duncan "Duckbuster" pup at the bridge....
TreeSlayer
did you get it done last weekend?
